recycler
Jul 17, 2013Explorer
jerem0621 wrote:
Check out this link for the 2000 Towing Guide
2000 Towing Guide
It mentions a HD towing package was required for the 2000 HD 3500 truck with the 5.7 in order to get the 10,000 lb tow rating.
I would do some googleing for the RPO code for the 2000 3500 series HD towing package.
The RPO codes should be listed in the glove box. I am sure a GM expert will chime in with more info here.
I "Think" that I read that the HD towing package consisted of a transmission cooler and a HD radiator.. but I may be mistaken.. I would google that as well if I were you.
Thanks!
Jeremiah
in 2000 the 3500 HD was a chassis cab truck..it has a solid front axle and 34in wide frame in the rear plus a 14,500lbs GVW and a 24,000lb GCVWR..
to the op yes it will safely pull it just don't plan on getting there fast if there is any big hills..
About Fifth Wheel Group
19,040 PostsLatest Activity: May 21, 2026
