enblethen wrote:
In Washington, a 4x4 locked in gear does not need to have chains unless the signs are out for trucks to use chains. You must carry chains! Normally you would install when required on the rear drive axle and on the last braking axle of trailer.
https://www.wsdot.com/winter/tires-chains.htm
If your vehicle is over 10k lbs GVWR or you are towing, you must chain up in WA even if you have 4wd anytime chain controls are posted.
Typically a single drag chain on the trailer can be mounted on any wheel of any axle that has brakes. If your trailer does not have brakes, you must still mount a set of chains/cables to one wheel.
