walthallm's avatar
walthallm
Towing Questions for a new fifth wheel
Wanting to upgrade to a larger fifth wheel and have some questions. I have a new 2014 f-250 super duty diesel. Looking at a Columbus 320 with a dry weight of 10,604 lbs and a hitch weight of 2015 lbs. Also looking at a Cardinal 3030 with a dry weight of 11,374 lbs and a hitch weight of 2550 lbs. Will I have any towing concerns with either of these units or any other problems with either one of these. Right now we tow a 30 ft Flagstaff at about 8,500 lbs.
  • Ditto on that look at the sticker on the driver side door post. Just guessing a 2500# hitch weight will put you over the limit. Don't forget that the hitch probably will weigh around 200#. My F350 only has a 3300# carry capacity your F250 will be lower. You need to add everything carried in the truck, fuel passengers and whatever else you are hauling.
  • All I can say is look at the weight ratings of your truck. That's what they're there for.
