Veebyes
Sep 26, 2016Explorer II
I'd be inclined to fix the problem & stop the chafing on the cross beam. Sooner or later it IS going to rub right through. No time is a good time for that to happen.
Glue a sacrificial wedge to the tank. Replace when it wears thin.
Running with a full tank should not be an issue, especially if it is only a small tank of 60gal or so.
Builders are notorious for building to bare minimum specs so before going off to the North I'd be thinking about reinforcing spring hanger areas of the frame, maybe even upgrading the spring pack by an extra spring.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
