mr__ed
Apr 26, 2014Explorer
FWIW, I never travel with a full water tank, only enough to use on the road if necessary (about 1/4 tank). However, in my case I always travel to RV parks where there is water at the site. I understand your needs are different.
Is it possible to use a water source closer to your destination so you can fill up when your almost there? I did that when I owned a motorhome some years ago. I was usually able to obtain water enroute from a fuel station by asking permission to fill my tank from their spigot at the side of the building.
I don't like the idea of hundreds of lbs of water sloshing around in the holding tank while driving, even if they're designed to handle it.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
