dieseldan723's avatar
dieseldan723
Towing with lifted truck
I just purchased a lifted truck (about 4 inch lift kit). The bed rails are just under 5 ft high. My rough estimates are that I would only have about 4-5 inches between the truck rails and the trailer. I can't back under it right now because it has a canopy.
What is the needed clearance to safely tow? I also realize that my 5th wheel will not be level and am wondering if that will be an issue?
DanD
  • We have trees here in the NW, and OP is in this area. Most of the lifted trucks here are freeway queens.
    Chris
  • Me Again wrote:
    What good is a lifted dually?
    I can actually think of many uses other than towing for a dually, especially one that has better ground clearance.
    Some of the back area hunting I used to do with my old SRW pickups are now off limits to me because my dually just sits too low to get into those spots.
    Shoot, a properly lifted dually would get me back into those areas again. I am not talking jeep trails here, but areas in the northern Great Plains where trees are not the problem but rocks, gullies and some ravines (small) are obstacles that a vehicle with clearance can properly navigate.
    Besides, as far as lifted vehicles go, a 4 inch lift is almost at beginners stage. I know there are lifts now in the 2 inch range, but at one time 4 inches was the lowest available.
  • So put it back to stock and go camping. Did you get the OEM wheel. What good is a lifted dually? Do you want to RV or look cool? Chris
  • rhagfo's avatar
    rhagfo
    Explorer III
    Is it 2WD? I have a stock 01 Ram 2500 4X4 and the back of the bed is 59" off the ground, and I have 6" clearance.
