GoPackGo's avatar
GoPackGo
TowMax Tires
My rig is exactly one year old and has been pulled around 9 - 10,000 miles. I just pulled into a campground here in Wyoming and noticed one tire looked kinda low. Pulled the wheel off and saw that the outer rubber was cut open about 3 inches on the inner side of the tire and had separated. This was not due to hitting anything. I think it blew 'softly' and slowly leaked down over several miles as opposed to 'explosively'. The tread also seemed to be raised upward and the mechanic said that meant it was separating internally. It still had 20 pounds of pressure in it. I figure that if I had driven too much further all the remaining air would have leaked out, putting the entire weight of the rig on that side onto the one remaining tire with possibly real ugly consequences.
I always run at 55-58 mph and always had the tires inflated to 80 pounds. Still had lots of tread. So they were not abused. I've read lots of tire posts on rv.net so I tried to keep an eye on them.
I had wanted to finish my traveling for this year (full timing) and then get new tires but NOT !
I understand that you can't judge when to replace an ST tire by the number of miles you put on them. But these TowMax tires seem to fail internally regardless of age or miles. Shouldn't I expect to get more then one year out of them ? No need to answer.
I really do think it should be illegal to sell (or install as OEM) TowMax tires. How can these things possibly be DOT approved ??
I now have 4 Maxxis M8008s ordered.
I'm not trying to restart the LT vs ST discussion. I've read lots of posts on the subject and made my decision. Maxxis ST tires seem to have a good reputation and owners seem to be happy with them.
OK, I feel better now.
Tim
  • But but they now have the Nylon overlay and should not do that~~~~~~~~~~
  • BlowMax tires are famous on here for failures involving explosions that do lots of damage. Your fortunate to have dodged a bullet!
  • That's why they call them "Blow Max" tires. On my 2014 BC (less than 1 year old and 5000 miles), after hearing many horror stories about Tow Max, I decided to change them out for the Sailun S637's. Got down to Big O and discovered that one of the tires had already separated, just like yours. I had no idea. You made a wise decision......
  • Even LT tires will break up internally under certain conditions (low pressure, curb strikes, too narrow of blocks under a tire..etc) I had a goodyear lose the entire tread down to the steel cords and still had 80 PSI. Luckily very little damage to the 5th Wheel.
    Sometimes it's tough to tell when a tire has an issue.
