Interesting. The current Grand Design RV in your weight range are 3-axle. They have a 17000 lb TH with 7K axles. I've looked at Road Warriors and others and anything above 17K is 3-axles. Your pin weight is 22%. With the 8K axles you still have almost 1000 lbs in "margin". That is much better than the 560 lbs on the trailer I used as an example. I wish dealers would put 8K axles on the larger 2-axle RVs now.
arhayes wrote:
First, I think you will find the pin weight on a loaded TH will be much higher than 20%. My GD 380TH 2 axle actual weight is 19,400lbs with a pin weight of 4,250lbs. That means the 2 8k axles are carrying 15,150 lbs. They have done so just fine for 6 yrs and 52,000 miles.
I have only been involved with RV ownership for those 6 years, but have never seen anyone post that an axle has failed. I’m sure it can happen....I’ve just not seen it. YMMV.
