Revivathread.
Have been using the camper here and there. Found a couple more issues that needed correction. The grey water tank valve wasn't working and a pipe upstream was loose.
The shower fixture was dribbling a bit. I went and bought a new fixture to swap out. Boy that was interesting. In this particular camper the fixture is about 6" higher than the kitchen cabinet behind it so the water goes through cabinet, turns 90 to vertical, then another 90 to the opening in the shower wall. I scratched my head a while then called a pro. Mobile service came out and had to pull the wall out from under the cabinet. Just enough room to reach the threads.
The A/C unit controls were kind of mangy looking and the vents were cracked up on both sides. Luckily Dometic sells a whole new panel for under $50. Swapped it out and cleaned the coils while I was at it. A/C working noticeably better since the clean.
Fridge works but not terribly well. I'll be replacing it before too long.
