rtazz17
May 19, 2014Explorer
noahrexion wrote:Ok,i figured part of reason was to gain more hieght.If I only had three inches space my rails would be crushed before I got out of my driveway with the uneven terrain I go around.I have about 7-8 inches clearance.Pullrite sells a three inch riser for the hitch you have.I have the riser on my pullrite.Its about 100 bucks If I recall.I believe its only for the kit that uses the frame rails.If yours is bolted into your bed then I dont think you can use it.
It is about 3" or so, this is part of the reason I'm lifting. Although in the pic I'm not hooked up.
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
