Tennessee_Nomad's avatar
Feb 24, 2016
TPMS advice
I'm putting new GY G614's on our camper this spring. I'd like to take as good care of them as possible. What kind/brand of tpms do you folks use/recommend? Does camper length have any bearing on my choice? Camper is ~37ft so the tires are a ways back there. I'm guessing these things are "wireless" so is one better than another? We are dual axles as well, so 4 sensors? Thanks for the help!
EDIT: Tires will be aired up 100+ lbs so it will need to read 3 digits?
  • Tireminders, easy to install and program, and their customer support is A1
  • klassic wrote:
    Do you need to rebalance the tires due to the weight of the transmitter?
    And why is there the choice of brass and aluminum?
    I don't have any experience with these (yet) but have been researching them. From what I'm reading about them the brass are the preferred ones because they don't corrode onto your valve stems. Again, this is what I read, but it makes sense to me.
    Dan
    I didn't, and I haven't noticed any imbalance vibration in the truck, either with the OEM tires or the Michelins I just installed.
    Dunno about the choice of materials unless it's to prevent galvanic corrosion with your valve stem material.
    Rusty
  • Do you need to rebalance the tires due to the weight of the transmitter?
  • I use the Truck Systems Technologies (TST) 507 system with the flow-through sensors on both the truck and trailer. I also use the repeater to boost the trailer tire signals up to the receiver. I'm very pleased with the system since installing it in mid-2014.
    Rusty
  • Good call on the new tires, I put on a new set of Goodyear 614 RST (235/85 R16) last year and I love them, they wear like iron!! I have the Tireminder Click on both truck and trailers, it's caught two slow leaks so far that could have been blow-outs (that was with the old set I used to have hence the up-grade) and I wouldn't leave without with out it. Tireminder gives me "real-time" info as to pressure and temperature at a glance and a very noticeable alarm when needed. One thing though I did add the antenna booster they offer as Wi-Fi on the road effects the reception and would recommend it off the start, Tireminder research is a great company to deal with if you need any customer support after-the-sale also they offer new replacement batteries and O-rings every year for free, a real class act!
    Red Green: Nothing bugs a handyman more than a stripper that works too slow.
  • Search this Forum for `tpms' then search the results for the manufacturer of interest. We are happy with our Pressure Pro.
About Fifth Wheel Group
19,010 PostsLatest Activity: Apr 18, 2025
