Bayley
Feb 23, 2018Explorer
TPMS Systems
I'm looking at adding a TPMS system to my rig. Based on cost and performance I've narrowed it down the EEZ-Tire and the Tire-Traker models. Does anyone have experience with these two products. As a...
Ron3rd wrote:You're correct about the sensor dropping off the screen. The issue is that it can take up to an hour to notify you that you've lost contact with a sensor, and then it will disappear from the screen. An hour is a pretty long time to be out of contact.fj12ryder wrote:
TST is a good system except for their excessive time for the monitor to notify you that it has lost contact with a sensor. It can take an hour for that to happen. Way too long.
My experience with the TST is that if communication with a sensor is lost, that sensor drops off the screen, alerting you to some sort of problem. In other words, you know it lost a sensor.
That problem (in my case) is always the distance issue since I went to a 35 ft TT. I've relocated the monitor but I'm at the distance limit so sensors will drop off. I'm adding the repeater to solve that problem
It seems there are some new brands out there that are performing very well too.
