So they say the arrow should be the mid range of movement?!?
Never heard that, but makes sense now that I think about it.
guess I've been putting too much air in mine too, but never over 100 psi when hooked up... with 2590 pin wgt I always thought more is betta :)
will have to adjust after a bit of riding and watching the rear view mirror on bumps and dips next time...
thanks for the insight gentlemen ! for those that stated psi they use, @ what pin weight are you running that pressure ?
OP - on you're earlier question - my bottom plate is parallel with the ground... and the top plate points 'up' at almost a 30 degree angle (it came that way from the mfg )
