bpounds
Aug 15, 2018Nomad
I think modest lift block are fine. You may have noticed that company doesn't offer more than 3" lift. To me that is pushing it, but if I needed 1.5 or 2" at the most, lift blocks are perfectly safe. Guys here have a knee-jerk reaction against them, but the fact is they are used universally.
The thing is, the prices from that company are outrageous. You're looking at $700 for two axles. Just about any decent sized town has someone who makes U-bolts, for a few bucks each. Any 4WD shop can advise you where to get them. And the blocks are obviously just some aluminum bar stock with a centering bolt. Centering bolts are also a common 4WD shop item.
It would be silly to build a welded lift frame for a 1.5" lift. More than that, yes definitely.
Remember, 1.5" lift blocks is going to raise the rear of the trailer a bit less than 3", give or take. Park your trailer on some 2 x 6 boards under each tire. See if that does the job for you.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 22, 2026
