- Winged_OneExplorer
timmac wrote:
Winged One wrote:
timmac wrote:
sin cal sd wrote:
nevadanick wrote:
I have a email saved from CHP that says i am legal towing two bumper pulls. Need Class A with doubles/triples endorsement and cannot exceed 65ft. I am not going to try and decipher Ca code which is why i asked CHP.
Thats odd. Ive asked multiple CHP officers from a few different districts and not 1 said it is legal because of the way the codes are written. I even asked our neighbor who is a city cop and he claims there isnt a VC thats says its illegal.
Nevadnick is right, you cannot pull double trailers in Cali without commercial licenses, you can do it in Nevada as long as your under 65 foot and under 26,001 lbs gross weight.
You can in California if you are from out of State and you are legal in your own State. Just to clarify.
No that's not true, just cause your state says its OK is not OK in another state, if so than all people from Colorado can bring their weed to other states..
However the post above did show this >>
In summary, nonresidents may tow two trailers with a non-commercial license IF their base state allows it. IF the vehicle is commercial, the driver would also need a valid medical certificate per 12502 CVC.
But note it says the if vehicle is commercial and RV's are not..
To claify, my statement is true regarding towing in California. If I am from Michigan, and I have a "Recreation Double" endorsement from Michigan; it is legal to do the same in California, following CA's restrictions on size.
Your State may vary.
And nobody was confused that I was talking about weed. I was talking about towing doubles. - Doughboy12Explorer
You need a reading comprehension class... It says "IF the vehicle is commercial, the driver would also need a valid medical certificate per 12502 CVC." - timmacExplorer
But note it says the if vehicle is commercial and RV's are not.. - christopherglenExplorerLink
VEHICLE COMBINATIONS - BASIC LAW
35401. (a) No vehicle combinations may exceed a total length of 65 feet. (See diagram: "California Legal Trucks")
(b) (1) A combination of vehicles which consists of a truck tractor, a semitrailer, and a semitrailer or trailer, may not exceed 75 feet, if neither the semitrailers nor the trailer in the combination of vehicles exceeds 28 feet 6 inches. (See diagram: "California Legal Doubles")
NUMBER OF VEHICLES IN COMBINATION
21715. (a) No passenger vehicle, or any other motor vehicle under 4,000 pounds, shall tow more than one vehicle, except for a tow dolly. (b) No motor vehicle under 4,000 pounds unladen shall tow any vehicle weighing 6,000 pounds or more gross.
465. A "passenger vehicle" is any motor vehicle, other than a motortruck, truck tractor, or a bus, as defined in Section 233, and used or maintained for the transportation of persons. The term "passenger vehicle" shall include a housecar.
362. A "house car" is a motor vehicle originally designed, or permanently altered, and equipped for human habitation, or to which a camper has been permanently attached. ...
410. A "motor truck" or "motortruck" is a motor vehicle designed, used, or maintained primarily for the transportation of property. (A pick up truck meets this definition.)
DRIVER LICENSING for DOUBLE TRAILERS - CALIFORNIA RESIDENTS
12804.9. (b) ..., any applicant for a driver's license shall be required to submit to an examination appropriate to the type of motor vehicle or combination of vehicles the applicant desires a license to drive:
(1) Class A includes the following:
(A) Any combination of vehicles, if any vehicle being towed has a gross vehicle weight rating of more than 10,000 pounds.
(B) Any vehicle towing more than one vehicle.
(C) ...
15278. (a) A driver is required to obtain an endorsement issued by the department to operate any commercial motor vehicle that is any of the following: (1) A double trailer. (2) ...
To apply for a commercial driver license, see this DMV web site: http://www.dmv.ca.gov/commercial/commercial.htm.
DRIVER LICENSING for DOUBLE TRAILERS - NONRESIDENTS
12502. (a) The following persons may operate a motor vehicle in this state without obtaining a driver's license under this code: (1) A nonresident over the age of 18 years having in his or her immediate possession a valid driver's license issued by a foreign jurisdiction of which he or she is a resident, ....
(b) Any person entitled to the exemption contained in subdivision (a), while operating, within this state, a commercial vehicle, as defined in subdivision (b) of Section 15210, shall have in his or her possession a current medical certificate of a type described in subdivision (c) of Section 12804.9, which has been issued within two years of the date of operation of that vehicle.
15210. (b) (1) "Commercial motor vehicle" means any vehicle or combination of vehicles which requires a class A or class B license, or a class C license with an endorsement issued pursuant to paragraph (4) of subdivision (a) of Section 15278.
For a valid medical certificate, see this DMV web site: http://www.dmv.ca.gov/dl/dl_info.htm#dl51medical. - Winged_OneExplorer
You can in California if you are from out of State and you are legal in your own State. Just to clarify. - nevadanickExplorerTinMac, we are 70 ft here. Used to be 75 with endorsement.
- timmacExplorer
Nevadnick is right, you cannot pull double trailers in Cali without commercial licenses, you can do it in Nevada as long as your under 65 foot and under 26,001 lbs gross weight. - timmacExplorer
Eyetattoo wrote:
In CA is it legal to toy a trailer behind a bumper pull toy hauler? If so what are the limitations?
Yes its illegal in Cali to do that, I know I check there laws, its also illegal to do that in a lot of states and if its OK in some states you also have to be under 65 to 75 foot depending what state..
So I spent $4500 and had a custom stacker trailer made to pull behind my motorhome and now I can go anywhere, even Canada. - nevadanickExplorerI recieved my answer from a sargent at the valley division of commercial enforcement. I am satified with his answer to my question to tow double bumper pulls in Ca.
- sin_cal_hdExplorer
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
