Pauljdav
May 16, 2013Explorer
I have the Dexter 4400# axle with 10" brakes and I can lock them up anytime I want.
The trailer is the 30RKS Cougar 8200 GVWR if that helps.
Given what you stated about the adjustment of the brakes I would make sure the voltage and amps were correct for each wheel. If that checks out I would pull the drums and do a visual inspection of each to see what is happening.
For your cold one I would suspect grease on the shoes since you had it on the face of the drum as well. very little really affects the braking.
Paul
Paul
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
