Buck50HD
May 16, 2013Explorer
Fulltimer50 wrote:
Trailer brakes aside, if you do some research you may find that Ford integrated brake controllers are not known to be the best you can get when compared to add on units.
Generally there is no braking when standing still, and they will not lock up. (unless you do it by hand)
It has nothing to do with the controller or main 7-pin connection. Everything is brand new, no corrosion. Our TT from last year had 12" brakes and was 7500 lb and would lock easily at a gain of 6 with this truck. Plus, while testing by hand, I used the break-away switch so the truck wasn't even involved.
Also, to others questioning grease contamination. There was a slight film, nothing substantial.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
