rockwind1
Oct 07, 2020Explorer II
Old-Biscuit wrote:
Sounds like brake controller and/or brake power wire to truck 7 pin is failing/shorting
Throws codes w/o trailer connected
Need to disconnect brake controller and check continuity on the Brake Power Wire from controller plug to the 7 pin on truck
No continuity then that wire is shorted some where on truck
Tekonsha Proportional Brake Controllers
will do , good advice.
About Fifth Wheel Group
