MFL wrote:
Caddy for 15K FW? I'm thinking modified fork lift, or bobcat?
Jerry
Explored all the same
Bobcat in decent condition = very expensive & may need accessories.
Fork lift - there are ready-made modifications available. Many/most dealers -and many repair facilities- use fork lifts to move 5th wheels. Ask around. Expect to pay about $2K or more.
Downside = *if* you need repairs that aren't DIY, you may need to transport an inoperative fork lift to a repair facility. Could be expensive! Also, used (cheap?) fork lifts may have seen better days.
Answer = Parkit 360. Mfg in Canada - Very impressive, but pricey!
Caveat/s from Parkit:
Do not exceed dolly's rated capacity.
Do not operate on more than a 4% grade.
The reps can (usually) be found at larger RV shows.
Good luck with your dilemma!
