jerem0621
Aug 22, 2014Explorer II
Lantley wrote:jerem0621 wrote:
Yawn....
It's not a myth at all. Half tons tow HEAVY every single day. Fivers, TT's, gravel...etc etc etc etc.
Folks it's about the operator, balancing the load, driving sensibly, working in the real world... Not about some silly sticker. That silly sticker in the door sill DOES NOT MAKE YOU SAFE.
Only you...the operator....can make any rig safe!
Thanks!
Jeremiah
You make a good point that ultimately it's up to the operator. However the ratings serve a purpose. Ignoring the sticker or ratings is foolish.
Failure to use the right tool for the right job is a common mistake.
But as you mentioned it's up top the operator to ensure things are safe. Operator error is a common catch phrase used when the operator
fails to act wisely
Winner winner chicken dinner.
The payload sticker (that silly inconsistent thing) is determined by the OEM not by any governing or oversight body that I can find.
People complain about Rams low payload numbers...however, if you sum the GAWR's you find up to 700 or 800 lbs of disparity.
If you look at a Max Tow F150 the payload is almost the sum of the Axles... Silly and inconsistent and untruthful in MARKETING.
So ones research must go further than just opening the door and looking at the payload sticker. What can the axles actually do? How about the tires?
While I do agree that most fivers are to heavy for most half tons. To say a half ton is "unsafe" towing heavy is a generalization. Why is an overloaded half ton unsafe while an overloaded 3/4 ton or 1 ton is just business as usual?
On this forum..not long ago...I pointed out that a new mega cab cummins ram loaded with nearly every option only had nearly 1800 lbs of payload per the sticker. I was quickly told that 1800 lbs would not even be felt on that truck.
Inconsistency...it really makes me chuckle.
Thanks!
Jeremiah
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
