Road Phantom wrote:
I'm interested in the 30 ft 1/2 ton tow-able 5th wheel from Grand Design's Reflection brand. Problem is the trailer sits too low for my standard 2019 Ram 2500 4x4 short bed truck. MORryde has a suspension kit (SRE 4000) that I believe raises the axles two inches. Larger rims would raise it up an additional inch, giving me a total of three inches which might be enough without compromising the overhang with the bed rails.
Anyone have the same problem and how did you resolve it? Thanks.
Check to see if you have spacers in your truck's suspension. If so, they can be removed to lower your truck. Might have to do the front axle, too.
While doing an axle flip is the easiest, it's been a long time since I've seen a FW that didn't leave the factory with the axles under the springs.
One thing not mentioned, is to be sure that the spring hangers are in the lowest holes, if you have them and they're not already done.
A Correct Track alignment system will give you 2" of lift, provided you can find one. I've heard they've been discontinued, though they were still listed on LCI's web site as of a month ago, or so.
Lyle
