shadows4
May 05, 2013Nomad
RoyB wrote:
Check with ETRAILER or AMAZON. They have a 7-way extension cable that might help you with your problem.
You may be able to mount this extension cable with just using a side bracket that screws into the inside of the truck bed.
Somthing like this maybe...
Roy Ken
I mounted mine much as Roy B did. I bought a 7-way T harness adapter. It plugs in under the bed where the 7-way on the bumper plugs into the truck wiring harness. I then ran the end up through the stake pocket much like Roy B has. Wire in a 7-way plug and your good to go! Good luck, John
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
