fowlthing's avatar
fowlthing
Trailer sway issies
View Profile
Posted: 09/03/22 08:26am Link | Quote | Edit | Print | Notify Moderator
2020 Model. Pulling with 2021 Ram 2500 Diesel. Have 3000 miles plus with no issues.
Now at speeds as low as 30 mph can hit a bump and side to side rocking translates into trailer sway. Worse going uphill. Had a trip this weekend and put two new tires on the rear axle. My tire shop only had two.
Is this axles out of alignment?? Shocks on the truck? ( 30k miles on truck).
I pulled the tires off and bearings are good. Measured and axles are same distance between tires. Did not measure to the pin.
Tread is still good on front axle. And was good on the two that were replaced. Wear is even. Could not detect that they were out of round when jacked up and spun the wheels.
Any help is welcome. Have years experience of towing trailers. The sway is dangerous. Not a slight annoyance. Thanks.
  • Not a dumb question. We just checked them and all tight.
    Measured from axle to the pin and they are the same distance.
