MFL
Mar 15, 2022Nomad II
trailer wheel weight rating/compared to tire psi rating?
My 6-bolt wheels on 5200 lb axles with oem 225/75R 15 D-rated 2540 max wt tires. My wheels are steel and are marked 2,600 max weight. My FW GVWR is 12,110, which would mean 10K max on tires/wheels. I have a 4K CCC, so FW never loaded to GVWR. I am thinking not much more than 8,500 lbs on tires/wheels most times.
I am planning to replace the tires this Spring. My first choice is GY Endurance 225/75R 15E with max rating 2,830 at 80 psi. I understand that at 65 psi, these tires would carry same 2540 as current D tires.
My question is...if I inflate these new E-rated tires to 80 psi, giving the tires full load carrying capacity, will the wheels take that increase in pressure? I will replace the rubber stems, with 80 psi rated stems.
Any of you heavy commercial haulers ever break a steel trailer wheel from a bit over listed max weight?
Jerry
