Cummins12V98
Mar 17, 2022Explorer III
Per GY Tech support
"when upsizing load range use the weight/inflation chart and add 5psi to what the chart dictates per your actual weights".
I personally discussed this when I went from GY "G" to GY "H" on my last Mobile Suites as I was at the upper end of the "G" tire load ratings. Seems I ran the "H" at 100psi or so for thousands of miles with perfectly even tread wear.
If they the tire manufacturer recommends the above I can't see why that is not ok for you?
About Fifth Wheel Group
