Cummins12V98
Mar 18, 2022Explorer III
CapriRacer wrote:Cummins12V98 wrote:
I would like someone to explain whey they have weight inflation chart for the ENDURANCE if it's not ok to run tires pressures based on actual load. ......
Those are MINIMUMS, not recommendations.
Sure but that is what the tire is designed to support at those pressures right?
Maybe you can elaborate. Do you disagree with GY tech support or agree that a person up sizing in load range can use the chart for the best ride, tire wear and stopping by adding 5psi to the chart.
Let's forget Jerry's rim pressure rating. If you went to the GY "E" 15" would you run the tires at 80psi or use the chart plus 5psi as GY Tech recommends?
Answer this. I am around 4,500# load on each tire and the GY "H" tires were not holding up running them at 125psi with a rating of 4,805#. Now I went with the Continental's with 6,005# rating at 125psi. Would you run 125 psi or lower pressure like 100 that gives 5,200# capacity?
About Fifth Wheel Group
