time2roll
Mar 18, 2022Nomad
Cummins12V98 wrote:I would go chart + 5 to 10 psi not to exceed the sidewall max if it is an LT or P tire. If the low weight is not on the chart I would use the lowest shown + 5psi. Run the sidewall max with an ST unless the ride seems stiff or bouncy. If there is a ride issue reduce to the chart +5.
what should I inflate my 6,005# tires to that the load is 4,500#????????? Don't seem to be getting an answer?????
About Fifth Wheel Group
