MFL
Mar 19, 2022Nomad II
eHoefler wrote:
"You have to replace the wheels to accommodate the higher pressure."
This man answered my question, right away, on first page. Not what I wanted to hear, but I think likely the correct answer.
My thread went off the track, turned foolish at one point. I may have hurt some feelings, trying to keep it on track. Hope not!!
I will answer CumminsV12, as to my tire edge wear from scrubbing, which is already described in my post on page one. Several of my tires show tread wear, on the edges mostly from my tight backing/severe side scrub, at home. I will not describe, but the black marks on my concrete driveway tells the story, as does my visible twisted wheels/suspension.
As to the tire inflation chart tire pressure, Capri was correct, a minimum. Using these minimum inflation charts, is not a one size fits all. They have charts for all types of tires. Truck tires, MH tires, single axle tires, not the same as an RV with tandem, or triple axles.
For FW tandems like mine, and some triples, also TTs, you can weigh your trailer, to get actual weight on tires, look at the RV specific chart. Now to find a very minimum, add 10% more air, could be 5 lbs maybe 10, but use 10%. Now that is a minimum, using 20% is better, if not going over sidewall max. Best of all, unless you have way more tire than needed, is to just inflate to sidewall max, for best protection from tire damage.
An ST tire gets it's strength from air pressure. To protect the belts, and avoid ply separation issues, from severe scrub, more air is better, all the way to max sidewall pressure, is recommended.
This post is not what my thread was about, but I feel is an important issue. If someone would start a new thread, maybe over on general, others may chime in with their thoughts.
Jerry
Jerry
About Fifth Wheel Group
