TXiceman wrote:
Cummins12V98 wrote:
"Having 3 axles over 2 axles, does not reduce the pin weight. What will reduce pin weight is to move the axles farther forward or add weight to the rear of the trailer."
You are the exception with a triple axle RV most are under 20% pin. Do you have a Gen, WD or big battery bank?
No generator, only four 6-volt batteries in the front left corner and the washer/drier is just forward of the left front axle and it is not a toy Hauler.
Ken
You simply have a high quality HEAVY RV that is not the norm.
