Puddles's avatar
Puddles
Transfering Hitch
Not sure where to post this... Have a 99 F350 crew cab with a 18,000 lb Draw-Tight 5th wheel hitch. Looking at a 2016 F350 with the 5th wheel package. Will the pre drilled holes in the new truck bed line up with the draw-tight rails? Are those holes only for a hitch from Ford? Man, talk about stick price shock... Thanks for any responses..
    I would contact Drawtite folks on their 1-800 number as they will know what you have and what you need....
    This from their web
    https://www.etrailer.com/5w-2016_Ford_F-350%20Super%20Duty.htm.
  • You can also get an adapter to fit the pucks in the new truck then you can attach your old hitch to it.
    B.O.
  • Cummins12V98 wrote:
    If your truck has the 5er puck prep sell your existing hitch and get the B&W Ford puck hitch, you WILL thank me!
    This ^^^^ B&W 3300 for OEM Ford pucks. About $950 free shipping.
    No your current hitch rails will not fit the Ford puck system.
    Jerry
  • If your truck has the 5er puck prep sell your existing hitch and get the B&W Ford puck hitch, you WILL thank me!
  • If I was a bettin' man, I'd say no. If you have the factory 5th wheel pkg, that's set up for the "puck" type hitch so your current one probly won't work. Others w/ more experience w/ this should chime in. My truck didn't have the 5th wheel pkg, so had to mount the rails to frame and drill holes up thru box.
