troubledwaters
Jun 28, 2017Nomad
ChuckV1 wrote:Not sure if you realize this, but a shorter radius means you have a higher potential to run up and over the curb. A longer radius means you have less potential to run over the curb. That would seem to me to give you less room to maneuver. Just my opinion.
I disagree on a couple of points, to me you have more room to maneuver because you hitch is over your axle and not on your bumper, thus you have the ability for a shorter turn radios.
In real life it's not such a straightforward comparison between a TT and 5er of comparable lengths. The pivot point is in a different location, the wheelbase from pivot point to axle aren't the same, the track the pivot points takes around a corner is different, the weight for a rear living room vs. mid LR may mean the axle has to be further back to get the proper tongue/ pin weight, etc, etc, etc. All in all, this whole discussion relative to shorter and longer (best and worse) is all magic smoke and two way mirrors.
About Fifth Wheel Group
