Greentow
Aug 13, 2013Explorer
Is you rig "generator prepped"? If not, you can get it done for less than $200. If it is, here's what I did. Run a 30 amp cord into the front under-belly, to the transfer switch, leaving about 3 feet from the kingpin. Wire into the transfer switch per it's directions. Wire the other end with the male that fits your generator. I ran the 30A cord thru the same gap as the 7-wire cable, using a fish tape. You can go a little longer with the male end of cord, and it'll allow the generator to set on the ground if you want, or leave it in the back of the TV for a quick stop. PM if I can give you more assistance.
About Fifth Wheel Group
