- carpetguy2ExplorerAlso depends on how high the hitch is too.Luckily I bought one at the dealer but would not fit with my HiRise hitch
So they had to return it and get me a nice roll up one . - rtazz17Explorer
mileshuff wrote:
If i fold it up to the first section my sliders release handle can hit the bakflip under certain conditions,example is 90 degree turn backing onto uneven ground side to side( it hit once already thats how i know and left a dent in cover)I have 8 inches of clearance of rails so thats not an issue.My brother owns same identical cover truck and camper and leaves it folded to first section but Ive warned him and eventually he will be somewhere and hit it but oh well warned him.Support rods when its up against window for cover are non issue,doesnt come close to those.rtazz17 wrote:
Mines a shortbox and I have no issues as long as its folded all the way up.
Folded against the cabs window or folded to the first section? I have a bakflip cover but have not towed since installing. If I fold it to the first section then rail clearance maybe an issue on tight turns. If I fold it against the cab window then the backflips supports may be a clearance issue. I have a slider hitch so am hoping there isn't an issue. Most others with a bakflip and shortbed report no problems. - Sundance07Explorer
greende wrote:
I have a Fold-A-Cover that folds in fours. No problems with mine so far. The reason I got mine is that folded, it doesn't stick up very far.
I have the same for my dually. Works well and no clearance issues. - mileshuffExplorer
Folded against the cabs window or folded to the first section? I have a bakflip cover but have not towed since installing. If I fold it to the first section then rail clearance maybe an issue on tight turns. If I fold it against the cab window then the backflips supports may be a clearance issue. I have a slider hitch so am hoping there isn't an issue. Most others with a bakflip and shortbed report no problems. - rtazz17ExplorerMines a shortbox and I have no issues as long as its folded all the way up.
- Trail-MateExplorerI have an Extang Tri-fold soft cover on an 8 foot bed, and I have no issues with hitching or towing with the cover folded, since you also have 8 foot bed I would think most Tri-Fold covers should work fine, I have heard the Tri-folds don't work well on shorter beds.
- rtazz17ExplorerSame here.Bakflip hard cover ..I do have to fold it all the way up against the window.I cant leave it down on bed when folded because it certain situations with my pullright when at hard angles and on unflat roads(as is when I back into my driveway)the handle will hit the cover.Happened once to me and left a dent in cover but dent is on underside so no biggie but Now I always fold it up against the window.
- machuntExplorerMan i hope you guys are right. mine is due here tomorrow how thick when folded?
- greendeExplorer III have a Fold-A-Cover that folds in fours. No problems with mine so far. The reason I got mine is that folded, it doesn't stick up very far.
- abc40kidsExplorerI have the Rugged fri-fold on mine and it stays on when hooked to the 5er. I keep my fire wood under it.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
