Paper maps are good as a last resort if all the electronics break down. On line mapping is fine provided you are connected. Useless if you are not. Stand alone GPS is fine for setting out a short trip. Not much good for a multi month trip using a route that is far from the most direct from one place to another. Inconvenient doing it all on that tiny screen. tap, tap, tap, tap.
Stand alone software like S&T is so much more flexible. Much more detail at your fingertips than a ton of maps. Much better for trip planning than any online service simply because you don't need to be online. Better than the GPS too. Plug into a GPS antenna & you have a navigator that has the info at the fingertips on whatever screen you want.
The stand alone GPS has its uses. We have always had one also for use primarily as backup to the S&T. Still using S&T 2011. Don't know what to do when the 2010 laptop it is on dies.
