JTrac
Apr 22, 2017Explorer
Are you using some pads under the jacks? We would get some settling on occasion which I think was related to the park site. Concrete ones no problem but gravel or grass seemed to settle because the jacks were slowly sinking just a bit. We now use about 6" of pads under each jack no matter what is under us.
May not help but if you have the Lippert system there is a service bulletin which says basically to remove a quart of fluid and add a quart of Torco racing fork fluid to stop the jacks from popping and cracking with movement inside the coach. I have the fluid but have not added it yet. We do get some of the popping especially when parked on a gravel pad. Like I said, if you have a Lippert Level Up system that will probably not help with the issue you are having but something you may want to have done.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
