Paul39
Sep 27, 2023Explorer
Truck / 5th Wheel Combo - Do the numbers add up?
Looking for input on my potential truck/5th wheel combo. A little background first. I have had trailers, but this would be my first 5th wheel. As I am opening this up to the weight police, I am looking for honest opinions and I don’t want to make a costly mistake. With that said, my opinion (as an automotive engineer) is that I’m a rule follower (regarding GVWR, etc) but I have no problem being close to the limit as I know there is a significant safety factor already built into those numbers. With that said – here is what I am looking at:
Tow vehicle
2023/4 Ford F250 4x4 7.3l gas short bed well optioned (maybe King Ranch)
From what I have found on the internet
Rear GAWR 6,340
Front GAWR 5,600
Tow Capacity 16,500
Payload 3,923
GVWR 10,500
Curb Weight 6,480 – 6550 (I see different amounts depending on what site I go to)
So – my math says 10,500 GVWR – 7100 Truck (added 550lbs for people/etc) – 200lbs for hitch (may need a slider) leaves 3,200 for pin weight. Assuming a 22% pin weight puts me at 14,500lb max 5th wheel.
I’m looking at a Cougar 290RLS
Dry Wt 10,124 lbs
Hitch 1,805
GVWR 12,200
Length 33’8”
I know many will say just get the F350, but the truck will be used 95% as a daily driver and 5% towing. Seems like I have a reasonable margin. ~4,000 lbs on tow capacity, ~500 lbs cargo capacity/GVWR assuming trailer is loaded to GVWR.
Does anyone see flaws in my logic before a spend a small fortune on these toys? Is the Curb weight of 6,550 for a short wb 4x4 7.3l crew seem right? I looked up all the specs for this particular truck and it seems consistent in that range, but comments on other posts look like the truck weight could be more. Also – any comments on the Cougar 290RLS?
Tow vehicle
Rear GAWR 6,340
Front GAWR 5,600
Tow Capacity 16,500
Payload 3,923
GVWR 10,500
Dry Wt 10,124 lbs
Hitch 1,805
GVWR 12,200
Length 33’8”
