lowfly's avatar
lowfly
Truck Bed Clearance
I just traded in my 2005 4wd F350 for a Ram 2500 4wd and love it. But, I didn't realized the bed, therefore hitch, was that much higher than what I had. I will be dropping the hitch a hole or two but I'm concerned that beyond that point I might be compromising distance between the bed and the 5er. Anyone else run into this since I'm guessing I should maintain at least a 3" space.
  • Same problem with my current set up. I ended up with 5 1/2" clear but wish I had a little more. 5 1/2" works, but I have contacted the fiver pin box overhang a time or two going down into a steep campsite.
    I raised my hitch instead of lowering the pin in order to have better visibility (when hitching) over my tool box. Consider that if your hitch is vertically adjustable (most are). I still pull a little high, but it's a trade-off.
  • I ended up with 5" clearance on mine and have not had any issues. In order to get 5er somewhat level I dropped my truck hitch as low as possible and raised the 5er hitch as high as possible, ended up with 5", the shop where I store it said it was sufficient as long as I don't intend to go 4wheelin with 5er in tow.
  • You are right on the 6-8". dont know what I was thinking with 3".
    Generally, 6" is considered a realistic minimum with 8" preferred. Can you tow with less.....yes, until you find out that you really can't (cue voice of experience and body shop invoice here - been there, done that and got the t-shirt to prove it with our 1st 5th wheel back in 1996. It still hurts to think about it!)
    Rusty
  • This is probably one of the most common reported issues on this forum. Only real option to retain proper bed clearance and tow level is to raise the 5er
