Cummins12V98
Oct 12, 2018Explorer III
4x4ord wrote:justme wrote:
The new Ford's F350 diesel SWR with the aluminum body have increased their CCW from 22k to 28k which means it will handle 18K GVW trailers. The weight savings with aluminum body allowed for a more robust frame and suspension while keeping the GVW the same as previous models. Anything over 18k trailer would need a dually.
18k is the max trailer weight for conventional towing behind a SRW pickup. 20600 lbs is the max weight fir fifth wheel/gooseneck set ups. I guess that must be figuring about 17% pin weight.
Gooseneck trailers will be about 15% pin and triple axle 5er's have much less pin weight than double axle.
I am at the max RAW towing my RV but could tow much heavier if it were a triple axle.
About Fifth Wheel Group
