4x4ord
Oct 20, 2018Explorer III
justme wrote:4x4ord wrote:
For fivers under 16000 lbs I believe the advantages of a SRW out weigh any advantage a dually might have. Many fivers over 16000 lbs and all over 20,000 lbs require a dually.
That was true for pre 2017 F350 SRW which has increased to 18000 GVW trailers.
18000 lbs is the maxomum convetional tow rating for the new F350 SRW. 20800 is the maximum 5th wheel and goose neck trailer tow rating for the new f350 SRW. The thing is the SRW trucks still have limited payload. By the time you load your hitch, fuel and family in the truck you don't have enough payload to handle the pin weight of many 5vers over 16000 lbs. As has been mentioned, there are some heavy tridem axle toy haulers and heavy gooseneck trailers that have relatively light pin weights.
About Fifth Wheel Group
