Why is a half ton truck called a half ton, or a ¾ ton truck called a ¾ ton? What does the tonnage refer to; is it how much the truck can carry or tow? I first learned to drive in the army at the ag...
I bought an M35 with the 478 cube multifuel and 5sp stick shift for less than $10k about a week ago. The engine was rebuilt sometime in the 80's. I'm going to build a camper on top of the bed. Good to know it will run on virtually anything from kerosene to jet fuel to avgas. Tho with the latter, it needs a quart of 30wt oil every 15 gal to keep the pump lubricated.
