RustyJC wrote:
Sport45 wrote:
As a quick screening check without looking at any numbers, I'm guessing your truck could handle just about any 5th wheel trailer with two axles. If it has three axles I'd take a closer look at the ratings.
Of course, you should always check the weights to be sure before buying.
A 21K GVWR DRV Elite Suites 38RSSA has two axles. Are you REALLY saying the OP's truck can handle it?
It should handle any 2 axle trailer, with single 15" wheels, and
most 2 axle trailers, with single 16" wheels.
If the trailer has duals, or 19.5's, all bets are off, pending further investigation.
