agesilaus
Mar 11, 2017Explorer III
work2much wrote:Jhurk wrote:work2much wrote:Jhurk wrote:
I have a 2014 Dodge Ram 3500 Reg box pulling a 2009 Cardinal 34'. I used the Anderson Ulitmate Aluminum hitch (35lbs) great hitchmfor a short box and 200 lbs lighter than some heavy hitches. I had to raise my Cardinal 5 " to make level but all is good. I believe the newer FW are taller to accommodate the newer TV.
Thanks. Is raising the trailer as simple as blocks and longer u bolts?
It's a little more than that to do it right I believe it's like a sub frame with a cross member for support.
Thanks. What I am trying to avoid.
Involves welding new perches too.
About Fifth Wheel Group
