JIMNLIN
Mar 13, 2021Explorer III
Well..... I looked at your coming back thread so you say you don't have a truck now.
The last 10 years or so the only 1/2 ton truck that has enough GVWR/RAWR to pull a 10k lb actual scaled gross weight 5th wheel trailer is Fords properly equipped F150HDPP like the one mooky stinks talks about.
Ford markets several F150 GVWR and RAWR packages all with a "Max tow" options. Don't bit into what many have done and choose the F150 with a 6800 gvwr and small 3800 rawr with the max tow option. This truck is good for around 1300-1500 lb load on that small 3800 rawr. Then they find out they chose the wrong F150....then claim a 1/2 ton trucks can't pull a 5th wheel trailer or only a tiny 5th wheel trailer.
About Fifth Wheel Group
