NC_Hauler
Jan 21, 2014Explorer
It appears that GVW on the Jayco 28.5 5er is only 9950...pin weight would be around 2,000# at the most...Don't see why you shouldn't be able to do this....if you're wanting to get a 5er. It appears the 27.5 weighs close to the same as below...Don't see where you would have any issues. The 27.5 is slightly lighter...
Eagle Touring Edition | 28.5BHDS
Weights
Unloaded Vehicle Weight (lbs) 7,205
Dry Hitch Weight (lbs) 1,310
Gross Vehicle Weight Rating (lbs) 9,950
Cargo Carrying Capacity (lbs) 2,745
Measurements
Exterior Length 31' 10"
Exterior Width 96"
Exterior Height with A/C 146"
Interior Bedroom Height 79"
Queen Bed 60 x 80
Bunk Beds 38 x 73
Hide-A-Bed Sofa 46 x 76-1/2
Wheel Base 240"
Tank Capacities
Fresh Water Capacity (gals) includes water heater 48
Gray Waste Water Capacity (gals) 65
Black Waste Water Capacity (gals) 32.5
Other
Sleeping Capacity 5-8
FLOORPLAN 28.5BHDS
+ Click to Enlarge Floorplan
Weights
Unloaded Vehicle Weight (lbs) 8,225
Dry Hitch Weight (lbs) 1,622
Cargo Carrying Capacity (lbs) 1,725
Measurements
Exterior Length 31' 7"
Exterior Width 96"
Exterior Height with A/C 145"
Exterior Height with Optional Bedroom A/C 146"
Interior Bedroom Height 73"
Queen Bed 60 x 80
Bunk Beds 36 x 72
Hide-A-Bed Sofa 42 x 60
Wheel Base 243"
Tank Capacities
Fresh Water Capacity (gals) includes water heater 73
Gray Waste Water Capacity (gals) 62
Black Waste Water Capacity (gals) 31
Other
Weights
Measurements
Exterior Width 96"
Queen Bed 60 x 80
Bunk Beds 38 x 73
Wheel Base 240"
Tank Capacities
Other
FLOORPLAN 28.5BHDS
Weights
Measurements
Exterior Width 96"
Queen Bed 60 x 80
Bunk Beds 36 x 72
Wheel Base 243"
Tank Capacities
Other
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 14, 2026
