cummins2014
Mar 18, 2020Explorer
RooDude09 wrote:
My wife and I are looking to switch to a fifth wheel from a bumper pull. I have a 2015 F-250 with short bed. The trailer we are looking at is equipped with a turning point pin box. I’ve seen and read some things on the internet that make me question the stability of system when towing and the blocking mechanism to keep the pin from turning in the hitch. I know my other option is to put in a sliding hitch and I’d be most comfortable with an automatic slider but that drives the price up substantially. My truck was previously outfitted with a rail system of some sort but everything is gone but the holes are in the bed. I’ve priced out the factory ford prep kit but it looks like puck style hitches are more expensive although I have the means to put it in myself as I’m a mechanic at a ford dealer. If anyone could give me they’re advice on what you like/use it would be greatly appreciated.
This thread is going to be fun, but if you already have the holes, bedrails ,and conventional hitch is a solid way to go. You will get to hear it all, but personally with your setup bedrails ,and a Andersen steel standard rail mount hitch would be ideal. Not sure if it would work with whatever that pin box you have ,but if it does it will eliminate the need for a slider, good way to go, I tow with a conventional slider hitch, and the Andersen with a short bed ,no issues either way. The Andersen route would be by far the most economical. If that pin box can be locked out ,the Andersen is the answer .
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
