MFL
Mar 18, 2020Nomad II
RooDude09 wrote:
I definitely want the extra clearance all the time so that if I need to make a tight turn) I don’t forget to look if the trailer is going to hit the truck.
With most newer model FWs having rounded front corners, designed for towing with 6.5' bed trucks, this is not as big an issue as it used to be. Certainly when backing short, clearance can become an issue, if not paying attention, no different than backing any bumper pull. Backing into a tight space, taking it slow, getting out to look when needed, is best option, no matter the trailer type.
Your Ford axle center is about 41"s behind the cab. If hitch pin is 40"s from cab, and FW front rounded, clearance would be a non-issue, in all but severe cases, when common sense/awareness is more critical.
Jerry
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
