JIMNLIN
Mar 21, 2020Explorer III
RooDude09 wrote:
I read the wedge can loosen up. I see someone has said you have to have the correct wedge so maybe that was the problem. The other problem of the pivot point being behind the axle causing sway was in an advertisement for a slider hitch so not sure what to believe on that. Haven’t had a chance to talk to any real people yet about it I definitely want the extra clearance all the time so that if I need to make a tight turn) I don’t forget to look if the trailer is going to hit the truck.
I never pay attention to what one person or a another brand hitch makers says about another product or how it will pull.
There are several top of the line rv type 5th wheel hitches on the market like the PullRite....heavier Reese hitches....same with the Kurt hitch which is a favorite with those that tow for a living.....B&W is another good hitch for rv work....Demco hitch systems....and of course the new gen hitch like the Andersen and PullRites Superlite system . One hitch isn't superior over all others.
As one poster says most newer 5th wheel trailers made for short bed trucks and have the rounded/notched front corners that eliminates the need for a sliding hitch or pin box systems like the one your looking at.
This is a area where the owners has to do the leg work. In other words there is no generic answer for which hitch is best or works best.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
