WTP-GC
Mar 21, 2020Explorer
ACZL wrote:WTP-GC wrote:
Rails suck. They are obsolete technology. Do they work (and work well)? Of course they do! But there’s exactly ZERO reason for anyone to go back in time in favor of obsolete technology. Plus, there’s exactly ZERO guarantee that a newly purchased rail system will match the existing holes from an old rail system. How do I know? Been there, done that.
Here’s an article warning of the same issue:
https://www.etrailer.com/question-135802.html
I’d much rather put that brand new 4” hole in the middle of my bed and get the best hitch combo option available vs. trying to maybe re-use some old holes that might not work and is regressive technology.
I’ve used an AUH aluminum and had no trouble with it. The friend I sold it to also has no trouble with it and he uses it for more than just RV towing. There’s nothing wrong with that product or the idea of a single point attachment.
Well if you have a truck w/o the puck set up, then rails may be the best way to go. Sorry my friend, but I disagree w/ your assessment. My last truck and current truck didn't have the puck set up and I already had a rail mount B&W Patriot and not about to go buy another hitch as the B&W was bought in '17. Had no problems attaching the B&W to rails for either truck BTW. I personally do not have an issue w/ the rails in the track 24/7. Does it block complete clean out? Yes. Does it not allow for a complete flat floor? Yes. Do I worry about it? No. Can I still use the bed of truck? Yes. Do I have to remove the hitch to do so? Yes. Do I care? No. As it was said before, some 5ers are not so well suited to be a gooseneck set up. It really comes down to personal choice. Are rails obsolete? No. But for some folks getting into yanking a 5er around for 1st time, they maybe the cheapest way to start off with.
In your case, you already had the rail mount hitch. That’s the most expensive part of the entire arrangement. So that makes sense to stick with the rails. In the case of the OP, he has neither the rails or the hitch. He’s starting from scratch. Having 8 each 1/2” holes already in the bed means almost nothing unless you have the rail kit that it was drilled for.
I completely agree that the rails are the cheapest way to get started. But now we’re back to the idea of saving dollar bills while you’re spending hundred dollar bills. You get your $40K-$80K truck, connected to what is probably at least a $30K or greater 5er, yet we get stuck on saving maybe a couple hundred dollars to use a hitch system which industry manufacturers are clearly trying to get away from. Doesn’t make sense.
If rails don’t bother you, then so be it. I don’t like them. So be it. Yet I make the same point...why use rails when there are much better options available these days??
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
