cummins2014
Oct 10, 2020Explorer
way2roll wrote:Cummins12V98 wrote:Jim Irish wrote:
We liked the new Montana High Country 281ck look and feel for our needs. Thanks for the you tube link.
3 questions :
1. Best way to get the new 281ck? Email a number of local dealers here in Atlanta?
2. Everything I have been told is a Ram 2500 4X4,diesel (max payload 2,170lbs and max towing 17170lbs) should not be an issue?
3. Can we go with a 6.4’ bed vs 8’?
Thanks for all the solid responses.
Jim
Sure you can compromise with the short bed but WHY??? Nice to have room for a large toolbox. There is not a single slider on the market that does not have issues.
At 14,300# the pin at only 20% will be 2,860#, you tell me a 2500 will be just fine! MOST people that use their RV's have over 20% pin and 25% is very common.
You are spending a lot of money do it right the first time.
This is good advice. Even with our smaller FW we chose to go with a long bed F350. Glad we did. The F250 would have been really pushing the limit and left no room for anything extra or an upgrade to a larger FW in the future. We also went with the long bed. I simply did not want to have to mess with a slider. No offense to those that have sliders.
No offense taken, but talking from experience ,been towing four different fifth wheels , with two different trucks ,both short bed 1 tons. The fifth wheels have been from 32' -38 ' long. Time period of nearly 15 years.
We are not full time ,nor ever plan to be. We use our fifth wheel 4-5 months a year. I have learned after 15 years ,you don't need large toolboxes in the bed, you don't need to haul everything ,but the kitchen sink :) etc etc. Full timing may be another story, but finding being away from home for 2 months or more, I can't see where we would need anything more if we were full timing.
Short bed a compromise , not hardly, but having the proper truck as far as weight rating ,yes thats the important thing. I have never wanted ,nor needed a long bed truck.
Hitches , I have towed with two different manual sliding hitches ,and the rail mount Andersen. If within the weight rating the four point attached steel rail mount Andersen is the only way to go. Short bed or long bed. I have the fifth wheel puck system on my Ram 3500, with the frame adapter , and I use the Andersen on that, as well as an 18K Reese manual slider. The only thing better would be an Andersen with the four point system attached directly to the puck systems on these newer trucks , without using a frame adapter. Unfortunately Andersen does not make one "YET" .The simplicity of the andersen far outways any other hitch , hands down.
This sliding hitch issue has been beaten to death on the forums. I can speak from experience , I don't need a slider towing with a short bed, many others do not either. There are some it would not matter slider or not they will have problems, its just a fact. Towing a fifth wheel takes a lot of awareness , and paying attention .
About Fifth Wheel Group
