Jim_Irish's avatar
Jim_Irish
Trying to figure out best 5th wheel? Advice appreciated
Wife and I are retiring next spring. Have looked at many brands of 5th wheels.
Our wish list on this is:
1. Easy to tow-aprox. 30-33 ft so we can get in state parks(have a ram2500 diesel-2020)-Next summer traveling out West for a couple months.
2. Has to be cold weather capable given we have boys in college playing D-1 sports in spring and fall in upper MW. We will be up and down many freeways...
3. Wife wants a newer model with the newer lighter interior.
4. Would like a model that we can access the bathroom and refrigerator while traveling.
5. Has to be sturdy/well built given the time we will be in it and I am not handy.
Somewhat narrowed down the list :
GD-reflection 150 -260rd 30ft
Pinecrest-looks to be well built and everything I read on it looks good.305rlp
Montana High Country - perhaps to long at 34 ft?295 rl-however meet a pastor yesterday that just bought 6 months ago and swears by it.
Artic fox and outdoors rv- tougher to get being in Atlanta and not cracked on interior
Ok- am I missing anything
Jayco -half ton
Wildcat......
Appreciate any feed back.
Regards,
Jim
  • Do your self a FAVOR!!! Get a 3500 RAM with Factory Rear Air Ride, AISIN and LongBed with a B&W Companion Puck Hitch.
    You WILL want a larger RV in the future. The 3500's with rear air set lower for easier entry/exit and a good ride.
    The AISIN like the Cummins are True Medium Duty.
  • I would look at Artic Fox as I did. Pasted my inspection but didn't meet DW's standards on interior storage and looks.
    That was however on the largest AF 5er we did wind up with the DRV in my sig.
    We are full timers and more often spend time in high temps than low. But we have found with night in upper twenties the fireplace heater will keep us warm for sleeping and kicking on the furnace for a short time in the morning will keep warm things up quickly.
  • If you are going to be traveling for extended periods make sure you get a model that has a full size shower. A lot of the shorter models still use the tiny corner showers.
  • joelc wrote:
    Research, research. It will take time and a lot of reading. The "best" rV for you might not be what the other person finds important. When I purchased my Carriage Cameo in 2012 I researched 5ers for over 6 months. I love my unit and have had near zero problems. I wanted a 4 season unit, constructed well and had good capacity. It is too bad they are out of business. Be sure you can tow what you get, maintain it well, and don't abuse it. Check ratings.
    I also think Carriage make the best built RV. Maybe that is why they are out of business.
    ALL RV have a life expectance of about 10 years. That is 1/2 die before age 10. Some live to a "ripe" old age.
    Purchase a floor plan you like and take care of it, maybe it will live to a ripe old age. The only thing that kill RV is water. It is the cancer of RV. What is to go wrong with a RV? Maybe a water pump, or a microwave. Easy to fix
  • The RV industry is plagued with poor quality builds. I've owned a pop-up, Class C and A, and three FWs (Cougar, Wildcat, Montana). The Wildcat's furnace failed on our first cold night, and the frame started showing signs of bending in the first year. I did a 3-hr PDI on the Montana and gave the dealer a punchlist for 15 items, several of which were serious, before I signed for the unit. It may be different in the so called luxury units like DRV and Luxe, etc. You said you weren't very handy, so be prepared to rely on a good dealer or RV tech to keep everything 100%.
  • I would look at Arctic Fox for what you want. They are built in Oregon and seem a step above the other junk on the market now.
    Or go back and find a nice used NuWa HitchHiker or a Carriage Cameo. From what we have seen, I would not consider anything from Forest River or Thor.
    With a 3/4 ton truck, you will need to make sure you are not over the trucks rear axle GAWR or cargo capacity. They cargo capacity will include the total of the pin weight, plus cargo, plus hitch, plus passengers. The actual loaded pin weight of a 5er is typically between 20 to 22% of the trailers GVWR. Do not use the brochure weights on the trailer.
    Ken
  • Research, research. It will take time and a lot of reading. The "best" rV for you might not be what the other person finds important. When I purchased my Carriage Cameo in 2012 I researched 5ers for over 6 months. I love my unit and have had near zero problems. I wanted a 4 season unit, constructed well and had good capacity. It is too bad they are out of business. Be sure you can tow what you get, maintain it well, and don't abuse it. Check ratings.
  • After six months I’m not sure any RVer, including a swearing pastor, can attest to the long term reliability of an RV brand. When you do buy and before you do any cold weather use, study the basics.
    Tell us more about your truck....GVWR, payload etc.
  • There is no best 5th wheel trailer....nor a best brand.
    Sounds like your going to need a real/full 4 season trailer. I would concentrate on the 4 season units such as higher R value in the floors/walls/roof in the floorplan you like. This type of input requires lots of leg work on your part digging out the mfg specs on their cold weather pack or "arctic pack"/etc.
    With the 2500 Ram your limited to wet pin weight around 2600-2800 lbs plus other stuff in the bed and in the cab before exceeding a its 6000-6500 ? rawr numbers. Over loaded above rawr means wheels/tires/rear suspension will have to be upgraded.
    You can get better/more input if you give us the trailer GVWR. WE can't tell anything about weights with a model number or a length.
    edit; I did a quick search on the Montana high country 29 RL....it has a 14300 lb gvwr which puts it in a one ton srw truck territory.
  • Very happy with our Cedar Creek 29RW. Checks all your boxes.
